Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4768 Cmd Rej: Invalid Link for hardware type E5ATM
If an E5-ATM or E5-ATM-B card is used, then a value of a, b, or a1 must be specified for the link parameter. A 3 Links per E5-ATM Card feature quantity must be enabled before the link=a1 parameter can be specified.
Recovery
  1. Display the cards provisioned in the system. Enter the rtrv-card and rtrv-stp commands.
  2. Display the status of the 3 Links per E5-ATM Card feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled.
  3. Replace cards as necessary. Refer to the Maintenance Guide and to the Database Administration - SS7 User's Guide for assistance.
  4. Re-enter the rtrv-slk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
