Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5316 Cmd Rej: FCMODE parameter is mandatory with FCGPL parameter
If the fcgpl parameter is specified, then the fcmode parameter must be specified.
Recovery
Re-enter the chg-eisopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
