Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2269 Cmd Rej: Unable to communicate with card at location
For the disp-disk-dir, disp-tbl, init-imt-gpl, set-lba, or set-tbl command, a keyboarding or hardware error may have occurred.
For the disp-disk-dir command, the card must be connected to at least one IMT bus.
Recovery
  1. Re-enter the command that generated this error message, specifying the correct loc parameter.
  2. If this error message appears again, perform the following:
    1. Press the F-11 function key on the terminal, to toggle it to its alternate mode, and re-enter the command.
    2. Investigate hardware factors including the LAN, card, and terminal.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
