Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3858 Cmd Rej: Host Name Still Referenced in IP Link Table
The value specified for the host parameter must be deleted from the IP Link table before it can be deleted from the IP Host table.
Recovery
  1. Display the associated IP address for the local host name. Enter the rtrv-ip-host command.
  2. Display the values for loc and port associated with the IP address from the output of Step 1. Enter the rtrv-ip-lnk command.
  3. Change the IP address for the location and port from the output of Step 2 to 0.0.0.0. Refer to the Database Administration - IP7 User's Guide for assistance.
  4. Re-enter the dlt-ip-host command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
