Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3417 Cmd Rej: NC is invalid for type-enttype combo
The type=gtwy and enttype=origninc parameters must be specified before the nc parameter can be specified.
Recovery
Re-enter the rept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Measurements Reference for assistance.
