Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4386 Cmd Rej: IP Address referenced in IPHOST table
The IP address of an existing IP link entry in the IP Link table cannot be changed if the IP address exists in the IP Host table.
Recovery
  1. Display the entries in the IP host table. Enter the rtrv-ip-host command.
  2. Delete the address from the IP Host table as desired. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the chg-ip-lnk command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
