Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2184 Cmd Rej: CLLI is already being used by a route
For the chg-sid command, the specified site CLLI code cannot be the same as an existing route destination CLLI code.
For the chg-dstn command, if the corresponding destination for the specified destination point code (DPC) is an adjacent signaling point (matched a Far End point code in its linkset entity set), the CLLI of the DPC cannot be assigned to any other destination address.
For the ent-dstn command, the value specified for the clli parameter cannot already exist in the Route table.
Recovery
  1. Display the self-identification parameters. Enter the rtrv-sid command.
  2. Display the entries in the Route table or SID. Enter the rtrv-dstn command.
  3. Re-enter the command that generated this error message specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
