Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2636 Cmd Rej: IPADDR assigned to a TCP/IP router
The IP address (ipaddr) cannot be in the TCP/IP link table and cannot be a TCP/IP router.
Recovery
  1. Display the existing TCP/IP router addresses. Enter the rtrv-ip-node command.
  2. Re-enter the ent-dlk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
