Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2475 Cmd Rej: Either TYPE or TTN must be specified
The type/typea/typei/typen/typen24/typeis/typens or ttn parameter must be specified.
Recovery
Re-enter the ent/chg/dlt/rtrv-gtt or the dlt-tt command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
