| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The UIM Threshold table is corrupt or cannot be found by the system.
Recovery
Re-enter the set-uim-acthresh command that generated this error message.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
