Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3446 Cmd Rej: SLK not provisioned for assigned Lhost
A signaling link must be assigned to the associated signaling link port on the local host before the open=yes parameter can be specified.
Recovery
  1. Display the linksets containing links assigned to the signaling link ports for the card. Enter the rtrv-slk command.
  2. Assign a link to the signaling link port for the new local host if necessary. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the chg-assoc command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
