Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2610 Cmd Rej: IPADDR assigned to a TCP/IP link
The value specified for the ipaddr parameter cannot already exist in the TCP/IP link table and cannot be a TCP/IP node.
Recovery
  1. Display the current IP addresses. Enter the rtrv-dlk command.
  2. Display the current TCP/IP nodes. Enter the rtrv-ip-node command.
  3. Re-enter the ent-ip-node command that generated this error message, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
