Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2623 Cmd Rej: IPPORT on node not assigned to specified LOC
If the ipport and loc parameters are specified, then the ipaddr/ipport combination must be assigned to the TCP/IP data link specified by the loc parameter.
Recovery
  1. Display the TCP/IP nodes in the database. Enter the rtrv-ip-node command specifying no parameters.
  2. Re-enter the dlt-ip-node command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
