Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5481 Cmd Rej: THRES parameter not valid when using threstype = SET
The thres parameter cannot be specified if the threshold type (threstype) has been changed to set.
Recovery
Re-enter the act-upgrade command, specifying a valid combination of parameters.
Refer to the command description in Commands User's Guide for assistance. Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
