Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3829 Cmd Rej: Link set with IPGWAPC=YES requires IPGWx GPL
If the ipgwapc=yes parameter was specified in the ent-ls command for the linkset specified by the lsn parameter, then the card application must be SS7IPGW or IPGWI.
Recovery
  1. Display the card type and the status of the ipgwapc parameter. Enter the rtrv-ls command specifying the linkset name.
  2. Revise the data as necessary. Refer to the Database Administration - SS7 User's Guide (SS7 links), to the Database Administration - IP7 User's Guide (IPGWx links), and to the Maintenance Guide (card replacement procedures) for assistance.
  3. Re-enter the ent-slk command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
