Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3725 Cmd Rej: Removable drive database level is not compatible
The removable plug-in flash drive cannot contain an EAGLE backup image.
Recovery
Caution:
It is strongly recommended that the act-upgrade command be used only in conjunction with the system Upgrade Procedure for your target release. The Upgrade Procedure provides step-by-step information on performing an upgrade.
  1. Verify that a backup image exists on the removable drive. Enter the command act-upgrade:action=dbstatus.
  2. If the backup image is present, follow the procedures in the Upgrade Procedure to remove the backup image. Refer to Commands User's Guide for a list of valid actions to use with the act-upgrade command. If the output from Step 1 does not show a backup image, re-enter the act-upgrade command.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
