Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2137 Cmd Rej: Port must be inhibited to change comm. attributes
The terminal port must be inhibited before the type, baud, prty, sb, and fc parameters can be changed.
Recovery
  1. Determine the status of the terminal. Enter the rept-stat-trm command.
  2. Inhibit the terminal port as necessary. Refer to the Maintenance Guide and to the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the chg-trm command, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
  4. Return the terminal port to service.
