Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4214 Cmd Rej: LOC and E1PORT parameter combination must be specified
For the ent-slk command, if the loc parameter indicates an SE-HSL card, then the e1port parameter must be specified.
For the inh/unhb-alm commands, if the dev=e1port parameter is specified, then the loc and e1port parameters must be specified.
For the rtrv-e1 command, the loc and e1port parameters must be specified together in the command.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
