Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3431 Cmd Rej: SCCPCNV must be ON before TCAPCNV can be ON
The SCCPCNV feature must be turned on before the TCAPCNV feature can be turned on.
Once a feature that is controlled by a feature bit is turned on, it cannot be turned off.
Recovery
  1. Display the status of the SCCPCNV feature. Enter the rtrv-feat command.
  2. Turn on the SCCPCNV feature if necessary. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the chg-feat command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
