Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2833 Cmd Rej: MTPRSIT parameter is only valid if MTPRS feature is ON
The ANSI MTP restart (MTPRS) feature must be turned on before the mtprsit parameter can be specified
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the MTPRS feature. Enter the rtrv-feat command.
  2. Turn on the If the MTPRS feature as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the chg-stpopts command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
