Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4370 Cmd Rej: Level 1 Alarm Threshold level must be less than Level 2
Each Level 1 parameter value must be less than its corresponding Level 2 parameter value.
Recovery
  1. Display the existing alarm settings. Enter the rtrv-th-alm command.
  2. Re-enter the chg-th-alm command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
