Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3904 Cmd Rej: DFLTACT cannot be ATIERR unless OPCODE=71
The opcode=71 parameter must be specified before the (n)dfltact parameter can be specified.
Recovery
  1. Display the current values for the opcode parameter. Enter the rtrv-gsms-opcode command.
  2. Re-enter the ent/chg-gsms-opcode command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
