Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4912 Cmd Rej: Disk invalid for specified Location
For the copy-gpl command, the specified disk type must match the specified location.
For the copy-tbl command, if a value of fixed is specified for the sdrv or ddrv parameter, then a value of 1114 or 1116 must be specified for the sloc or dloc parameter.
For the format-disk command, a value of of 1114 or 1116 must be specified for the loc parameter before the type=fixed parameter can be specified.
Caution:
Contact My Oracle Support before entering the format-disk command.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message occurs again. See My Oracle Support (MOS).
