Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5296 Cmd Rej: CDGTMODID/CGGTMODID must not be specified as NONE
A value of none cannot be specified for the cdgtmodid or cggtmodid parameter.
Recovery
Re-enter the command that generated this message, specifying a valid value for the cdgtmodid or cggtmodid parameter. Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
