Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2412 Cmd Rej: Command already in progress
If the act/chg/copy/rept-stat/rtrv-gpl command is in progress, then no other -gpl command can be entered.
If a chg-ctrl-feat command is in progress, then another chg-ctrl-feat command cannot be entered.
If the copy/init-ext-stats command is in progress, then no other -ext-stats command can be entered.
Recovery
Re-enter the command that generated this error message after the system has completed executing the command in progress.
