Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2118 Cmd Rej: IP address already in use
For the chg-snmp-host command, the specified IP address is in use for another SNMP host.
For the ent-snmp-host command, the specified IP address is in use for another SNMP host.
The entry for the specified IPADDR can not already exist.
Recovery
  1. Enter the rtrv-snmp-host command to display the existing IP address provisioned in the SNMP Host table.
    The IP address must be unique to the SNMP host.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
