Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3472 Cmd Rej: Timer value and SRCTSET cannot be specified together
A timer value and the SRCTSET parameter should not be specified together.
Recovery
Re-enter the chg-m2pa-tset command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
