| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the ndialpfx or dltpfx parameter is specified, then the dialpfx parameter must be specified.
Recovery
Re-enter the chg-ainpopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the INP/AINPQ User's Guide for assistance.
