Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3101 Cmd Rej: Maximum number of GTAs already provisioned
A maximum of 32 GTA values (for 32 IN platforms) can be defined in the PPSOPTS table.
Recovery
  1. Display the entries in the PPSOPTS table. Enter the rtrv-ppsopts command.
    If the table is full, then an existing GTA value must be changed to the new GTA value.
  2. Re-enter the chg-ppsopts command that generated this error message and change an existing GTA value to the desired GTA value. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
