Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4365 Cmd Rej: Either TLNP or ISUP NP with EPAP must be enabled
The Triggerless LNP (TLNP) feature must be turned on before the tlnp stop action can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the TLNP feature. Enter the rtrv-feat command.
  2. Turn on the TLNP feature as necessary. Refer to the ELAP Administration and LNP Feature Activation Guide for assistance.
  3. Re-enter the chg-gws-actset command that generated this message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
