| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The ANSI41 AIQ feature must be enabled before the chg-aiqopts command can be entered.
For the chg-mtc-measopts command, the feature must be enabled before the mtchaiq=on or mtcdaiq=on parameter can be specified.
For the chg/rtrv-sid command, the feature must be enabled before the cpctype=aiq parameter can be specified.
For the ent/chg/rtrv-srvsel command, the feature must be enabled before the (n)serv=aiq parameter can be specified
For the ent/chg/dlt-ss-appl command, the feature must be enabled before the appl=aiq parameter can be specified.
For the rept-ftp-meas command the feature must be enabled before the enttype=aiq parameter can be specified
Recovery
