Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2414 Cmd Rej: PC does not exist in CSPC group
The point code must already exist in the CSPC group specified by the grp parameter.
Recovery
  1. Display the point codes currently assigned to the group. Enter the rtrv-cspc:grp= command.
  2. Re-enter the ent/chg-map or dlt-cspc command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
