Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2866 Cmd Rej: TFATCABMLQ is invalid for C-link sets
The tfatcabmlq parameter cannot be changed for C linksets, because C linksets are the primary route for mated STPs.
Recovery
  1. Display the linkset information. Enter the rtrv-ls command.
  2. Revise the linkset configuration as desired. Refer to the Database Administration - SS7 User's Guide (SS7 links) or to the Database Administration - IP7 User's Guide (IP links) for assistance.
  3. Re-enter the chg-ls command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
