| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the nec=none parameter is specified, then values of asdrnnecdn, rnasdnecdn, rnnecdn, rngrnnecdn, and grnrnnecdn cannot be specified for the dra parameter.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the Commands User's Guide and the INP/AINPQ User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
