Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2931 Cmd Rej: SEAS Gateway Screen Set names can not be changed locally
Gateway linksets must be configured from a SEAS terminal.
Recovery
  1. Display the terminal information. Enter the rtrv-trm command.
    The TYPE column displays SEAS when a SEAS terminal is used.
  2. Re-configure the terminal, if desired, or re-enter the chg-ls command that generated this error message from a SEAS terminal. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
