Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3769 Cmd Rej: Too many sockets per SLK
The allowed maximum is 1 connection per signaling link on IPLIMx cards.
Recovery
  1. Use the rtrv-assoc command to see the SLK configured for the association under consideration.
  2. Re-enter the chg-assoc command to configure an association with a unique SLK and socket combination.
Refer to the command description in Commands User's Guide for assistance.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
