Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4477 Cmd Rej: Terminal cannot be changed to type SEAS
The type=seas parameter cannot be specified if:
  • The value specified for the trm parameter is 1 - 16.
  • Specifying the parameter results in more than one SEAS terminal on a type IPSM card.
  • Specifying the parameter results in more than two SEAS terminals in the system.
  • An IPSM card is not physically present in the corresponding location.
  • The SEAS terminal specified by the parameter values does not exist in the SEASCFG table.
Recovery
  1. Display the provisioned SEAS terminals. Enter the rtrv-trm command.
  2. Display the cards in the system. Enter the rtrv- card command.
  3. Re-enter the chg-trm command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
