Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4376 Cmd Rej: Maximum matching Route Exceptions already exist for DPC
The 6-Way Loadsharing on Routesets feature must be turned on before more than 2 routes can be provisioned with the same relative cost for a given exception route criteria.
Recovery
  1. Display the existing exception route entries. Enter the rtrv-rtx command.
  2. Display the status of the 6-Way Loadsharing on Routesets feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, the feature is not enabled. if the feature has a status of OFF, then the feature is enabled but is not turned on.
  3. Delete an existing exception route or enable and turn on the 6-Way Loadsharing on Routesets feature as desired. Refer to the Database Administration - SS7 User's Guide for assistance.
  4. Re-enter the ent/chg-rtx command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
