| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the ent/chg/dlt-ss-appl commands, the Equipment Identity Register (EIR) feature must be turned on before the appl=eir parameter can be specified.
For the chg-gsmopts command, the EIR feature must be turned on before the eirgrsp, eirsptype, or eirimsichk parameter can be specified and before the eirimsichk option can be specified for the on or off parameter.
For the ent/chg-map commands, the EIR feature must be turned on before a true point code value for the pci or mpci parameter can be specified
For the chg-mtc-measopts command, the EIR feature must be turned on before the mtcdeir=on or mtcheir=on parameter can be specified
For the chg-sid command, the EIR feature must be turned on before the cpctype=eir parameter can be specified
For the ent/chg-srvsel commands, the EIR feature must be turned on before the (n)serv=eir parameter can be specified
For the ent-trace command, the EIR feautre must be turned on before the imei parameter can be specified.
For the rept-ftp-meas command, the EIR feature must be turned on before the enttype=eir parameter can be specified.
Recovery
