Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2497 Cmd Rej: NI, ZONE, MSA, UN or NPC cannot be C for existing blocked SR
The point code c-c-c, or the npc=c parameter can be specified only for a screening reference that does not alerady exist.
Recovery
  1. Display the existing screening references. Enter the rtrv-scr-blkdpc or rtrv-scr-blkopc command.
  2. Re-enter the ent-scr-blkdpc or ent-scr-blkopc command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
