Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4246 Cmd Rej: Command driven loopback in progress
The act-cdl command cannot be specified for a link that is already performing a command driven loopback test.
Recovery
  1. Display the links that are in command driven loopback. Enter the rept-stat-cdl command.
  2. Re-enter the act-cdl command that generated this error message after the test is complete, re-enter the command for a different card and link, or stop the test and re-enter the command. Refer to the Maintenance Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
