Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5415 Cmd Rej: Feature can not be enabled with non-SMXG VSCCP in system
For the chg-stpopts command, the ANSIGFLEX option can not be turned ON if DSM is equipped in the system and one or more following feature are Enabled.
  • 1100 TPS/DSM for ITU NP
  • Port
  • AINPQ
  • ATINP
  • EIR
  • G-Flex MAP Layer Routing
  • G-Port
  • Info Analyzed Relay Base
  • INP
  • IS41 GSM Migration
  • Prepaid Short Message Intercept Phase 1 (PPSMS)
  • MO SMS ASD
  • MO SMS GRN
  • MO SMS IS41-to-GSM Migration
  • MO-based GSM SMS NP
  • MO-based IS41 SMS NP
  • Portability Check for MO SMS
  • TIF Number Portability
  • TIF Number Substitution
  • TIF Subscriber CgPN Blacklist
  • V-Flex
  • TIF Selective Screening
For the enable-ctrl-feat command, the following features can not be enabled if the ANSIGFLEX system option is ON (see the rtrv-stpopts command) and a DSM is equipped in the system.
  • ANSI-41 INP Query (AINPQ)
  • A-Port
  • ATINP
  • Equipment Identity Register (EIR)
  • G-Port
  • INP
  • IS41 GSM Migration (IGM)
  • MO SMS ASD
  • MO SMS GRN
  • MO-based IS41SMS NP
  • V-Flex
Recovery
  1. Enter the rept-stat-card:mode=full:loc=<Service Module card location> command to display the card type in the system.
  2. Remove DSM card(s) and replace with either E5-SM4G or E5-SM8G-B card(s) as necessary. Refer to the Maintenance Guide for assistance.
  3. Re-enter the command that generated this error message. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
