Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4812 Cmd Rej: SLKTPS is required for IPSG linksets
If the ipsg=yes parameter is specified, then the slktps/rsvdslktps or maxslktps parameter must be specified.
The ipsg=yes and adapter=m3ua parameters must be specified before the slktps/rsvdslktps or maxslktps parameter can be specified.
Recovery
  1. Display the attributes of the linkset. Enter the rtrv-ls command.
  2. Re-enter the ent-ls command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
