| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the action=disp and tbl=lnk parameters are specified, then the rloc and link parameters must be specified.
Recovery
Re-enter the dbg-ddb command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
