| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the act-slkcommand, a link cannot be activated if the tst-j1command is in progress on the same port on which the particular link to be activated is configured.
For the tst-j1command, only one port test can run at one time on the J1 port specified by the j1port parameter.
Recovery
