Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2141 Cmd Rej: Invalid FC value specified
If E5-MASP hardware is used, then a value of hw or both cannot be specified for the fc parameter.
Recovery
  1. Display the status of cards in the system. Enter the rept-stat-card command.
    A value of E5MCAP is shown in the TYPE field when E5-MASP hardware is used.
  2. Re-enter the chg-trm command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
