Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4526 Cmd Rej: MAP table is full
For the chg-map command, the mate point code in the command will exceed the maximum number of entries in the MAP table.
For the ent-map command, one or more point codes in the command will exceed the maximum number of entries in the MAP table.
Recovery
  1. Display the entries in the MAP table. Enter the rtrv-map command.
  2. Delete entries as necessary. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
