Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2600 Cmd Rej: Linkset SAPC referenced by route
A Secondary Adjacent Point Code (SAPC) linkset cannot be deleted if a route exists for the linkset in the SAPC’s domain or group code.
Recovery
  1. Display routes associated with the linkset. Enter the rtrv-rte:lsn= command.
  2. Delete the route as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the chg-ls command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
