Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3273 Cmd Rej: NIC, SI, H0/H1, and PRI entry already exists in given SR
If the screening reference exists, the nic, si, h0/h1, and priorities to be added to the allowed SIO entity set for the SIO screening reference cannot exist in that allowed SIO entity set.
Recovery
  1. Display the valid settings for the screening reference parameter. Enter the rtrv-scr-sio command.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
