Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2408 Cmd Rej: CSPC broadcast group already exists
If the pc parameter is not specified, then the value entered for the grp parameter cannot already exist.
Recovery
  1. Display the CSPC broadcast group names. Enter the rtrv-cspc command.
  2. Re-enter the ent-cspc command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
